Settings in firestick
Fire. Stick will not let me go to manage apps in settings keeps kicking me out
Hello @Revav77 have you tried restarting your device?
Yes several times every thing else in settings works fine
@Revav77
Factory reset it, unplug it, let it rest try again. Use the adapter so it has power from the wall not the TV.
Have tried All the suggestions still not working
If you’ve factory reset your device and it is still doing that, I would venture to guess that the device is shot.
Hope not only one yr old
@Revav77
Contact Amazon on this, it’s probably faulty.
What exact Firestick do you have? I’ll research but I tend to agree with troy on this one. If a factory reset and subsequent updates did not give you access to manage installed apps, then it may be done.
