I keep getting an error code in seron. It tells me to check the log for info.and it has stoped updating the new sessions on some shows.
How do i fix this
Mine just started do this also. I’ve done all the troubleshooting and nothing. It could be Seren is down. I will try a few other things. If I find a fix I will let you know.
Hi @8750
Welcome to the community and thanks for your question.
So with Seren, most common error is installing the scrapers. It’s also important to integrate real-debrid.
Here is Troy’s full tutorial. Follow it, and remember, to capitalize the S when installing the scrapers package.
Are you still having problem? Mine started working fine again on both my Fire sticks.
