Seren sort and filter
Seren has updated and sort and filter section is new Any idea what the proper settings for this would be or just leave it at default
Hi @Art
You could leave them as default; you can change them. After the last update, I had to go back in and change a few. I changed the file size to 1080p from 4k since I don’t have a 4k TV. Changed one or two others, just to help speed it along some.
I also changed max size down from 10Mb to 5Mb
I have mine said to 1080 also but I will send it to five instead of 10 also I think they need to come up with a new scraper package it doesn’t seem to get some of my TV shows very well where other add-ons do thanks again
Hi @Art
I assume you are using real-debrid?
