Only as of yesterday Seren is not progressing past the “starting engines” page with the logo when a movie is selected. It hangs then there is a “look at the log” message.
Anyone got any ideas - 1. The get it going, and 2. How to find the log.
Using Kodi 19.3
Same problem. Following
It’s working just fine.
Make sure you are one version 2.1.9
Little fuzzy. Make sure everything seren is updated the other problem could be all your space or resources are used up. Make sure you have active space on your devices.
Also go into your settings under addons and make sure to install updates automatically
I have the most recent app. Seems to be working now. I understand that there may have been an issue with Real Debrid recently. Maybe this was the cause.
Thanks
