Seren a standalone addon or build?
I thought Serene could be loaded as a standalone addon like The Crew. I don’t want a build because all I need are Movies and TV shows. If not I’ll add on Oathe as another. Thanks
Hi @Remy
Yeah, Seren is not a stand alone APK, but a add-on in Kodi.
@Remy
You don’t need a build for it.
OK stupid me, but where are the so-called packages they want? I have set up everyting else including my Trakt and RD acounts. Thanks
Hi @Remy
Try this:
Provider Tools> Manage Provider Packages> Install Package> Web Location> http://bit.ly/a4kScrapers > Install>ok Then hit your back button a few times to go back to Kodi Home Screen
I tried exactly this URL 5 times and could not get the scraper to load up.
Check your spelling including uppercase for the S.
That’s the same link I used for the scraper package and it worked for me.
I’ll have time tomorrow to work on this so I’ll let you all know
I did, very intently, especially after the 2nd time.
