Hi, I read over a previous thread but it didn’t seem to answer what I’m having difficulty with. I’m trying to find the setting to allow 3rd party apps on my 2019 Samsung QLED tv. Everything I have seen on google and duckduck go has been a dead end. The instructions I find tell me to access setting tabs that my tv DOES NOT HAVE! I have searched everything in my settings to no avail. My amazon fire tv box broke and it’s not in the budget for another at the moment. Does anyone know how to find where to allow 3rd party apps on this particular tv so that I can try to side load? Thanks!
As Samsung is not an Android OS and so APKs can’t be directly installed on it and it has a Tizen OS I suggest you carefully read this article and follow it’s instructions. Patience is the key. It isn’t easy but it is doable.
Thank you! I will give this a try!
