I have a Element Ti8. When I power it down, it reboots itself & powers back on. Has anyone else had this problem? If so, how to correct it? It didn’t always do that. I suspect one of the apps, but which one?
That’s typically a sign of overheating or a hardware malfunction.
I would get the troy app installed get unlinked and look for a app that cleans up your software. I then would delete unneeded apps.
Keep what you use, then get a app that shows you the Temps. If it’s to hot it will reboot or power down.
Cleaning up your app data usage and general app usage does help.
If I understand you correctly, when you shut your device off it restarts without your input. I’m not familiar with your device but I suspect there’s a setting for auto start after shutdown or from sleep. This could be an app, as mentioned, or the device settings itself. Sorry I can’t be of more help.
Post deleted by user.
