If you setup usb storage on the firestick and set it up to be all internal, does that mean if you record on tivimate then it will be recorded to the usb flash drive with the added internal storage for later viewing.
I really dont need to partition the drive . I just want the added internal storage for recording on tivimate
For recording I believe you need it formatted to external. For apps only, format to internal.
If you use mixed in the partition command the number (60.40) would give you 60% Apps and 40% downloads on the USB drive. You can specify what you want.
