Real-Debrid's Anti-Piracy Hit: How Fatal Was It?
Does RD flush its cache every so often so that old links are lost?
I am not entirely sure how RD does business but I suspect they cleared a ton of cached DATA in order to follow the judgement brought against them. That might have reduced the number of available seatch results.
This is what I believe to be how RD operates
RD does not store content, your app grabs links from a series of websites, or you get the links from specialised websites.
The content you download or watch is uploaded to third party servers by people around the world, not affiliated in with RD.
RD only buys premium accounts to those services that host content, like RapidGator, FileFacrory, nitroflare, turbobit etc.
The same with torrents, they only cache popular torrents downloaded by many users often, content grabbed from popular torrent sites.
Any cached content not downloaded in 30 days from their servers will be deleted.
My understanding was they they did cache torrent files and that’s what they cleared or stopped doing to meet their legalities. Here is a quote.
ā€œReal Debrid or All Debrid are two services that allows you to download and stream all kinds of content from software, music, games,prn… up to 4k movies (40gb+), that are hosted on suported premium file hosters like Rapidgator, Uploaded, Filefactory, Turbobit, Nitroflare…at great speeds(1+ Gbps). They also caches a lot of movies torrents, giving you instant download/streaming, without the need of seeders. Basically instead of subscribing to a few hosters at 80+ usd/year each, you subscribe to Real Debrid and they subscribe to a lot of hosters instead, and then give you acces to any content you want from those suported servers.ā€
But then who knows the truth of these quotes.
Real Debrid not working well on CinemaHD, works on Flixvision.
finish-him-fatality
I’ve been using RD with CinemaHD - no problems at all - tons of streams
I was subbed to RD for years and started having problems so I just let it run out and switched to All Debrid it works just as good as RD.
I’ve been using RD for years but I only use one add-on (Twilight) in Kodi that provides me all the tv shows and movies that I could ever want. I never had any issues with RD and just renewed my service two days ago without issue. I’ll stick with them as long as possible.
Had a good experience with RD until it became a tad flaky and of course when it went down. Premiumize came to the rescue. Then I had an issue and posted it to their customer service expecting a long time for a response especially with so many time zones between us. In less than 15 min I got a response and a fix that worked immediately. Hard to beat that level of service in the telecommunications industry which is usually awful.
welcome
I do not get any RD links in Syncler. Also, I am not impressed with the PM links I get. Am I missing a Syncler setting or two?
I don’t use syncler. I have absolutely no problems with PM and always have great scrapes and sources. I always spend the time, when getting a new service, to go through the settings from start to finish, including testing their various server locations to get me the best speeds and least buffering possible.
I’m with you @teehar ,gonna re-sub for a month , then go for 6 if I get good results , and keep premiumize in back pocket, Thanx
I just renewed for 6 months. The only difference I see is that they got rid of Amazon Pay. The links work great on Cinema and Cyberflix!
What version of Syncler are you using?
For the stable version you should be using v1.3.9.2 and for Beta you should be using v2.0.0.45
You can update to any of these versions using the Syncler installer.
Can you please tell me how your set up?
I used to use Kodi but since CinemaHD had Realdebrid as a host, I switched to using CHD for all my movie streaming.
CinemaHD with Realdebrid misses a lot more than hits on any of their streams, so I switched to Premiumize, which works good, but not as to good as RD did with it.
If RD works for you still, please let me know what you are running, because I would like to go back to using RD rather than having to use PRMIZE.
welcome
@jorom I noticed you found my reply to your question funny some how and you didn’t respond.
If you aren’t running the latest releases then RD will not work on older versions.
If you are running the latest versions I hope you sorted but if not, did you try disabling PM in Syncler force close and clear cache?
Then try playing RD links.
I rebooted my Shield Pro and am now getting pretty good RD links. The PVDR links I get work about 50% of the time though.
