I get the following message when I try to enter a name for newly established link from beetv into real debrid. Can anyone offer advice on what I am doing wrong
Yes as mentioned by @Sbrowne126 after the slash it should be device, but here are the correct steps to re authorize RD.
Before authorizing your RD account.
First open a browser and login to your Real Debrid account from PC/laptop.
Then click on Authorize Real Debrid from the application, a message will pop-up with the authorization code.
From your Real Debrid account navigate to device a link will open “as shown below” with a field to enter the authorization code you received from the application, few seconds later your authorization will be activated.
Note: Don’t Authorize your Real Debrid from this platform, but open the link from your PC/Laptop when you logged in to your Real Debrid account.
