Is real debrid down cant get anything to play
Ok thanks for the reply AMD237
Appears to be back up now.
I did notice no RD link this morning. RB is good about extending our subscriptions, when there it is down. I’ve noticed that it has experienced more downtime in 2023. Wonder was happening behind the scene.
Rumors I heard, stated they were the focus of a lot of DDOS attacks.
Wow things are getting to crazy.
RD has already add 2 days to my subscription. Yay, RD back up and running.
Yup. They’re a top knotch crew for sure. I’ve used them for a long long time.
Yes it will be a shame if they go after RD! The best.
Received the message while watching venom saying real -debrid down for maintenance!!!
Some of their past DDoS issues stemmed from certain apps that had auto resolve enabled, generating 3-4x request traffic, crashing their server.
So, should auto resolved be disabled on all apps? Most of my apps were preset to enable auto resolve.
I have been using RD for over 5 years and never messed with any auto resolve setting
There were post versions that were patched so that auto resolve was off by default.
Thank you so much. I had to disable in Cinema HD. The other apps I use didnn’t have that feature. I’m all set now.
Again thanks for sharing
