Real debrid not working on cinemahd
all of the sudden realdebrid stopped working on cinemahd. won’t let me log on and give a number to enter on redbrd website. Just keeps saying wait, then goes off. Any solutions.
Thanks,stick
If none of that works and you did everything correctly and your sub time is not expired, you will have to wait. This is a them issue not us.
Looks as if RD is down - I’m only getting uncached torrents as well as Trakt error code 502 on KODI.
Just started happening in the last hour or so.
If so, then we wait. We cant fix Rd on our end. Take a look at their twitter page too.
RD down all over the planet according to FB.
Same here…Seren on Kodi as well
I’ve tried everything o can think of
I’m not any links at all on either one
Uuuggghhh - I’m having to watch the free torrents & getting buffering like crazy!!
I’m getting error messages on Seren too…
It won’t load to get a code
@JediJudy
Then please wait for it to be back up.
This has happened before. It usually is fixed overnight
I’m having the same problem using cinema HD. Can not log into RD
Real debrid is down PLEASE WAIT.
Yep it’s down. Wife got me to fix the stream and I noticed it wouldn’t play any real Debrid links. Hopefully back up soon
