is it possible to send me one as well ? thanks
Iād like one was well. thanks.
I have been frustrated for years trying to find a quality IPTVā¦To compound your issues, I am Canadian and getting live Canadian channels for news and beloved hockey has been near on impossibleā¦Upon Troyās recommendation, I tried ādigitallizardā several weeks ago @ $8 USD a month (cheaper for extended time frames)ā¦I have been thrilled and will extend my subscription upon renewal
What are the prices ?
visit thier web site and see
Could u send to me as well kind sir?
When I went to sigh up for Hive, I asked them if Hive had catch up service. They told me that if I wanted catch-up, the best option me was Falcon Hosting. Falcon Hosting is from the same group as Hive. So I got Falcon hosting, itās also 15.00 mo. I have been happy with Falcon Hosting but I mainly use it for catchup. It has totally ended my need to record.
I am trying out the hive now for a month. I assume Falcon also has live tv and catch up? If so, wondering why I wouldnāt just order Falcon instead for the same price? @Tico259
Congrats and happy for you. And yes that is home to Hive, Falcon and Creed hosting. ![]()
TX, was that response to my question? If I want live and catch up, I should use Falcon instead? Same type of quality? Thanks.
Solid performing catch up is awesome.I mean I can record via tivimate or sparkle if need be,but havenāt had to since having danko.
same service, different functions. Hive=5 connections, 3 ip no vod or catchup ā¦the others have different variations all stated on the site.
got it, thank you, as always!
Hey Amd
Invite link to discord not working
PMāed you just now. ![]()
Hi! Iām new to the community, seems like Ho0ter and danko may be good iptv. Iād like to check them out! Can I get their discord link so I can join the group?
Thank you kindly!
ITTech Basics had an outage a few weeks ago but they worked all night to fix it. Their communications on this issue with me was excellent. This service works great.
i had their service but they wont tell you when your bill is due? and if you forget to check their site for payment due? they cut off your service so i canceled them
I had another service that did not notify me on renewals. I continued the service until I found ITTech Basics, which was way better and bought an extended subscription. You just have to keep note of your listed expiration date on the bottom of the app and renew it accordingly. In my mind, if the service is that good, no renewal reminders is a minor issue.
