I have the Green Monster 19 build on one device and Slamious on another, both use The Crew add on. When searching on either build on anything it comes up as usual with lots of links but always goes through them all and ends with no stream available. Any ideas, apart from a fresh install of both builds, please. UPDATE. My Real Debrid had expired that will teach me.!!!
Is RD authorized on both? If it is, try re-authorizing.
Yes it is and thanks I will try that.
I am a complete idiot my Real Debrid had expired. I am normally so careful about this but hey ho lesson learned. many thanks for the help.
Re authorize your account
