I just got a notification that YouTube and Netflix had updates. When I click on the update it says not enough space and it tells me to manage my Apps. I only have the bare minimum on the cube everything else is on the USB.
I usually delete the Apps reload them and then use Mixplorer to bring them back onto the USB. Does anyone got any suggestions? Thank You all in advance for your sage advice.
This YouTube video should explain exactly what you need to be able to use your USB stick as storage -
Because the stick has to be formated specifically for the Cube make sure that anything important on it is saved somewhere else before you start - Because you are already short of space - something like Dropbox may be a good way to do this.
I have followed all of TDUK instructions for this and it works like a charm. Nevertheless, I still have the update problem that says I don’t have enough space, manage your applications.
