Problem updating Oceanstreamz
A little more info would be nice but I imagine it’s probably the same thing as I had . You need to go to oceanstreamz website for the update that is what I had to do hope it helps you out
I have been on to their web site to download the update, it is not working.
They say there is a problem with it. So I have deleted it I will wait till they get it working again.
What version you looking for. ad free 2.1.5?
All they said was problem updating I know from past experiences you can’t update from the app when you try it tells you to go to there website and download from there. They did that and they’re having problems with the website I guess. That’s why everyone always says backup backup backup
Thanks everyone. I figured out that I had to go to put oceanstreamz.com in downloader and then click on apk
Ya I just had an altenate source for the latest APK in case the site was down.
