Hello
I am using mx player for the cinema had apk , was wondering if the in built player is any good as I am trying to free up a bit more space in memory
Thanks
I always used the internal player with Cinema. Unless you want some special features, there’s no real reason to use an external player.
I’m using MX player with CinemaHD and it works ok. It won’t scan in fast forward it just jumps 10 seconds ahead. And it gets wonky if you try to back up. After I found this with MX player I change back to the native player and it was the same way. It’s annoying as I usually want to skip the opening credits.
