The APK downloads but then I get a Parse Error and it does’t install.
Use the Search key above and type in “Parse Error”; it’s been talked about here a few times previously and mentions a couple things you can try…good luck.
I’m getting that for a few of the apps in troypoint app as well.
The only time i get it is in troypoint app. Trying to download and install IPTV Extreme
Tried again the next day and it worked ok! Don’t know why it didn’t work the first day.
