Hope some one can help. Recently moved on from my fire stick and am now using the Onn box. I can get everything to work but it does not sync with anything I am viewing on stremio or my Iptv service. There is aslowing of the video and the voices are 1-2 seconds behind the mouth movement. I did follow the troypoint set up and did install Project Ivy and not sure if that is causing the issue. Any help would be great.
That is strange that it is happening on everything you watch. Have you tried restarting the box to see if it fixes that? Settings - System - Restart
Perhaps someone else can assist but you could have a defective box. I’ve had a few audio issues on my ONN boxes but doing a restart always clear it up
Had that same problem recently. I turned off and unplugged my ONN, I turned off and unplugged my modem/router for about 10 minutes. Then powered up and turned on everything … result … problem solved!
Ok I will give it a try and let you know. Thanks for advice.
Well the problem returned. Since the latest update I’ve had problems with the ONN and Stremio doesn’t work on T95 Plus at all. Now using an APK to watch, huge bummer. Not gonna reboot everything everytime I want Stremio.
I by no means have the expertise to provide advice; however, I switched my player from the installed palyer to the Bear player and it seemed to fix it. I tried the Mx player and could not get sound. But my wife watched an episode of the lincoln lawayer and she said it was great. So try swithcing palyers and see if this works
Here’s a fix that works. Delete Stremio 1.9.x
Use Downloader code 259421 to install Stremio 1.6.12 (stable)
When Stremio gets their act together, maybe we can upgrade.
Stremio’s sloppy rollout of “upgrades” should be a boon to apps like Nuvio, STRMR and others!
I have upgraded to 1.9.8 and have no problems at all. I wonder why the difference.
Did you upgrade ONN box or Buzz?
Upgrade on T95 plus box renders the app totally inoperable
Reddit is full of complaints. YouTube has multiple recent examples of how to downgrade.
The Buzz. That’s why I wonder what the difference is. Very odd. Ya I’ve fielded a few questions asking if I know why. I can get the old versions easily.
If I were to guess, it’s the processor chip. Buzz is very powerful, ONN less powerful and T95 even less. ONN buffers and lags, T95 can’t runthe software.
If that holds true, Stremio could be making a mistake believing users will just run out and buy a handful of the most expensive boxes with the most powerful chip.
i am having the same problem started 3 days ago
I use pay center live for my IPTV and once I swithced to Bear player everthing is fine the picture is also better. Try swithcing your player.
