Any found the latest mod of ola tv? All unlinked codes are old versions.
If anyone is having success with a mod pack let me know. Thanks
I Have Ola16. I’ll send you the site link in a pm.
Thanks Miki, I will give it a go. I heard about the “K” site and now I found you. Bit of a legend
Keep up the good work.
Is it the same downloads for Android devices, as I have android now and gave up on firetv.
Thanks
Yes, works on Android just fine.
