NVIDIASHIELD not turning on
Nvidia shield will not turn with and without remote
Did everything new batteries new power cord nothing any ideas
Will not turn on? Off? … I would just try a cheap usb remote and see if that works just to elliminate the remote as rhe problem. Have you tried the shield remote on your phone from the app store?
You probably have to “re-pair” the remote. Go into Shield Settings and you’ll find it in the remote settings.
