Hello,
I have been using an HDD to “expand” the storage capability of my nVidia streaming box for years now. Finally, the disk is showing signs of wear amd tear and is making mechanical noises. I want to replace it with an SSD.
The issue is doing a transfer cleanly, and transparently to the installed apps. I want to know what is your recommendation on how to do it best, if possible. Actual apps have been installed in the HDD, not just data. Will I have to remove and reinstall those apps manually, or is there a way to “transfer” them. As some of these apps are a bit cumbersome to install, I want to ask before I start that time consuming process.
BTW: There is storage space in the device.
Thank you!
