Since the recent Nvidia updates to the Shield, I no longer have the option to select external USB storage when recording. Before update I could select either internal or external location. Anyone know A fix?
If you are using Tivimate. Then select System Picker.
Thank you, I am not using Tivmate. I have tried various versions of the app and none allow me to chose external storage to send recordings to since the Nivida updates.
Can you go into your file manager and manually assign your recordings to your external storage?
Not sure how to do that on the Shield. I’ll look and see if there is A File Manager listed. Thanks!
Download a file manager such as X-plore, ES File Explorer, etc… I use X-plore for its simplicity.
