i did a search here and still unsure how to clear cache on this nvida shied pro, do you clear cache and then data from an app but then app starts all over and you lose any info am i missing something i only clear cache i never clear data did that once and lost everything on kodi and had to start over thanks for any help
For individual apps just force close and clear cache. You can clear data, but you may end up needing to sign back in and reconfigure your settings for that app. I use the Background Apps & Process Lists to facilitate this process. Background Apps & Process List - Apps on Google Play
Another very easy way to clear all Cache Data on your Nvidia is to go to settings>Device Preferences>Storage>Internal Shared Storage>Cached Data>OK Then do the same for the USB Drive>Cached Data>OK
This last way clears ALL cached data for every app you have on your Nvidia all at once, but does not force close any app.
Powerfader ! Dose this method erase your app data ?
No, clearing cache data in this way is not the same as “clear data”.
thanks guys i do use background Apps & Process list but when i clear cache there are still like 16.38 kB left there is that normal if a clear data lets say on kodi it deletes my addons on firestick cache it would go to 0 and i never clear data
There is always a small Cache left after clearing. Initially it will show 0 but close it or switch to another app then go back into it and you’ll see a small cache. That’s normal now.
thanks Miki for your help just trying to learn things with my new shield pro
Long press your home button to bring up a neat feature. Double click your home button to bring up recent apps you’ve opened. Single click your hamburger button to enable your AI. Double click the hamburger button to open your settings.
This clears cache on all your apps
Android settings > Device Preferences > Storage > Internal Storage > Clear Cache > OK
One click clears them all. This is good for all Android TV, Nvidia, Roku etc.
For $200 it should clean my catche! LOL.
$164.99 …jus sayin’
thanks guys for your help
Everything is more in California!
And everything is bigger where Ron’s at…
I just checked an ad for the pro down here $450 USD.
list is toast.
Dang that’s a lot of pesos.!
How close are you to the border?
About $9000. That’s the problem here. Ugoos was the same.
Driving about 20 hrs.
Take the wife and you on a road trip.
