đŸ„‡ Nuvio Setup MasterClass by TROYPOINT
That’s just it miki im getting the message on black screen and no scrapers. And why would it work in stremio using same add ons
Are you sure the sources are identical. Same encoding, same resolution, same supplier etc? Lots of small things to do like adding your Debrid service API in every addon, and configuring the addon for cached only or ignore uncached sources depending on the addon. Making sure to select the res you want and ignoring things like cams and TS. Selecting priority language It takes a bit of learning for sure.
Well I shared the addons from stremio. And, nuvio worked fine for two days and suddenly it did this. Then after I got the screen I got the meteor scrapers and comet just kept spinning.
I’m not on your system and can’t monitor exactly what you are doing. But it’s so easy to simply delete an addon and reinstall from scratch just to ensure that nothing went wrong with the copy/paste and install. That way you know it’s fresh. Can’t comment on the two day time frame you quote as I wasn’t there for the initial install. All I can do is to recommend that you may want to start from scratch following Troy’s MasterClass video on say a tablet or phone while doing the actual install on your streaming device. That way you can pause the vid while you complete a section of the install on your device and can rewind/replay/pause the vid as needed. All I can tell you is, it does work and although you may not want to hear it, there must be something wrong with either the install or addon setup. As an example I use DuckStreams, a very technical addon if using the advanced setup and it took me literally 32 installs/uninstalls before I finally got it right, not to mention countless hours of researching exactly what some of the terminology means, all of that needs to be done on your end. Or simply follow Troy’s MasterClass video very carefully, and before you say “I did” I believe you and have heard it dozens of times before, only to find out that a “/” was missed or a “.” added where one shouldn’t be and we have all done it, you certainly aren’t alone, but persevere and you will get it.
So I checked my addons on stremio, and the addons on nuvio were identical settings . So I tried nuvio just a minute ago and it’s working fine. :person_shrugging:t2:have no idea except maybe nuvio fluked. I did get an error earlier last nite , but did a force start and clear cache and it fixed it. Also I originally put or tried to put addons like Troy said because didn’t want to use bootstrapper and when I’d configure it would put them on stremio. That’s why I shared, copy and pasted to nuvio
Nice work.
Appreciate this
made primary setup easy. I
m trying to set up multiple profiles in Nuvio, but when I try and use boostraper to sync it always synced to the primary, even after I switch profiles. Any tutorial on how to use multiple profiles on Nuvio with bootstrapper? tia
This is what I was wondering. I recently downloaded stremio. It’s decent. I have an issue w the loading of movies
I dont know what it is about Kodi but my brain can not understand how to use it. I should deep dive some more vids
I installed Nuvio according to Troy’s video and it’s apps. Is Media Fusion worth installing as well for live TV? I created the URL link for the install on the Media Fusion website and put it in Nuvio but it doesn’t show up as installed on my Onn Box.
I don’t recommend Nuvio for live TV. More for VOD.
I can’t seem to find one for unlimited or KCP I think they came from an unlinked. I don’t use them I have paid TV service.
Try this one for Turks 8178206
Voltra 1165642
Two questions, one for Stremio and two for Nuvio. On Stremio I can get subtitles but can’t fast forward or rewind. Any thoughts on what’s happening here?
On Nuvio I can’t get subtitles and also can’t fast forward or rewind. Never had this problem on Kodi add-ons so not sure what to do.
Anyone had this happen and been able to fix it?
When watching a vid on Stremio click the down arrow on your remote to open the lower panel. That gives you the controls, and more, that you are looking for.
What do you recommend for live TV on Nuvio and where do I find it? One person said Unlimited but I don’t know where to download it.
I don’t use Nuvio, Stremio, or Kodi for live TV. I use apps like TiViglass and TiVimate for that.
Is there a way to use two Debrid services with Debrido? I see there is only an option to add one.
You create two debridio addons. One for say OC if using it and one for PM if using that one and add both to Nuvio or Stremio independently.
Thanks a ton!
You are welcome. Sometimes things like this aren’t so obvious. Enjoy.,
