I am having trouble with sound on Cinema movies. Many have no sound whatsoever. Any help would be appreciated.
Hi @DimJim
Welcome.
So a couple of things to try first.
- Uninstall and then reinstall it.
Install Cinema HD APK on Firestick/Android in 30 Seconds (October 2021) - Next go into settings >applications>cinema and click force stop then followed by clear cache.
So if that helps. If not, come back here and will see what else maybe going on.
What player are you using? Sounds like a codec issue to me. Be sure if using say MX Pro that you choose HW+ for decoding. I remember that months ago we use to have to add a codec in MX to get it working properly. So be sure that you are using the latest updated apps.
On top of what @Miki said you will run into codec issues with links that have surround sound.
You will need to manually install codecs into mx if you get a audio error on playback.
But changing players will help resolve your sound issues with hw+
I think that is the problem. I changed players and got sound but not surround sound. Thank you for your help
