cant get any real debrid links on bee tv im signed in to bee tv real debrid account
Re authorize your account
Delete your devices in real debrid and re add them
Well follow the steps from @TP-Dracoo.
But to review the BeeTV settings again, check the manual from TP. Scroll down to table of contents to check the settings again.
did all that except, delate your devices, explain which devices
do you mean all apks or just beetv ? i logout & login
I may edit that, i mean login your Real-Debrid and delete all connections ans re setup your connections to your real debrid supportesld apps.
Eatch time after entering the authorization code, the next screen it shows up to enter device name, this will be saved in your RD account under devices with all devices saved earlier.
@TP-Dracoo suggestion worked for me after deleting the devices history I was able to reauthorize RD.
