No Premiumize links with Kodi
Still down for me as well. Switched from real debrid after they started logging. What options are left that do not keep logs?
Neither Premiumize or Real Debrid working for me either.
Real debrid is working for me.
No mention of outage on the Premiumize.me X account.
Don’t think completely down - they started logging IP and email addresses so many switched at that point - as did I.
Nope No way. Real Debrid had issues for like 3 days and then most of the KODI developers fixed a workaround on their Addons. Not sure about the other APK’s. My sub is good through July 2025 and been working flawlessly since the initial hiccup
RD working perfect for me in KODI. Using it right now
So I have the crew and I’ve been using premiumize for six months without a problem and now all of a sudden, it says when I try to resolve the settings again because it wasn’t working before error, check the log it won’t let me re-authorize premiumize into the crew. Anybody know what happened all the sudden
Its backup now. Just reauthorised my account
8:55pm and Premiumize back up here. :+1:
I just checked and RD and Premiumize is working here.
I’m wondering if somebody accidentally tripped over the power cord at Premiumize and shut the servers down. Otherwise maybe just a glitch?
I’m using weyd and my real debrid is still active but I haven’t had any links since it went down
Premiumize up on stremio
Mine is back up
Been using KODI since 2016. Never used Weyed. Don’t understand why people do
I’m not to tech savvy and kodi was a lot… I find weyd easier
Mine worked too. Thanks!
Premiumize up and running with Weyd
Troy’s and Jayhawks tutorials have really made it a lot easier to handle the ins and outs of Kodi. Kodi is what I started with so I’m fairly comfortable with it. BUT you have to use what works for you and your comfort level. Heck easily a large group of Insider swear by Stremio which is great.
This will help get your RD links working again with weyd
https://troypointinsider.com/uploads/default/original/3X/1/f/1fd05044c11a913329b82c36637f6a9492d779d4.jpeg
The Weyd dev was one of the last to implement the RD API fix.
Which I thought was poor because users actually pay for the app.
