Have Surfshark, IPVanish, Nord etc undergone a similar audit?
Yes for all three you listed. Happy to see PIA take a step forward.
I did come across this if it’s any help to you. There were several other articles that came up as I Googled it. This is posted in the SS Blog from a 2021 Audit
PIA is a great vpn and i use it. It also has a key showing you are connected over your apps.
I use PIA on the Stick, with the VPN Dot. PIA is also on my Android tablet, where I rely on the PIA Key in place of the Dot to let me know the vpn is on. I have not found a way to display the Key on the Stick, however. Have you?
I haven’t used it on my firestick really. So im not to sure. But i could try. I dont use these apps on my stick so no need for the vpn.
But i can take a look.
