I have tried and tried to activate “Next Episode” using Seren build. I did find a box which I checked for play nexr episode, but still no luck. Am using Kodi 20.
I don’t use Seren But how difficult is it to back out to the episode list and choose the next one. You can still binge it might just take 10 seconds longer. Or you can always go back to that paid Netflix sub
I use the same and sometimes it’s because the credits are really long…Netflix for example and/or it’s the first time you watch a program. Honestly some shoes pop up quicker than others. Either back out or wait patiently
Good Luck
