Should be a backup option in Smarters I believe, Also not sure but you might be able to just change the url for your playlist and apply changes without losing your favorites. You can do this in Tivimate, so you might want to switch to it. Much better player.
Thanks I’ll look at your suggestion.
I’ve been sampling a few irptv services, but will look at Tivimate, not seen that one yet.
I appreciate your feedback.
Just to clarify, TiViMate is not an IPTV service, it is a player that you enter your service url in, to get their playlist, and it’s EPG. The free version is not worth it imho, and will not give you a true all around quality experience. The premium lifetime subscription is the real gem and is around $35 for life.
I don’t think there’s a way to save your favorites when you get new codes. What I did is initially years ago on DirecTV I typed down all my favorites on a sheet of paper put it on my computer. What I did on my fire stick as I took pictures of all my favorites is a different channels then again I typed it up put it on the computer. It helps quite a bit. If it helps if the provider puts the channels in order some kind of organized order.
Thank you for that information.
Thanks, that’s a good idea. I will take a pic of the list.
What a pity we can’t save the favorites list, it would be a most useful addition.
I guess we can’t complain too much, we are getting TV for ‘almost’ free.
I installed the xtreme info provided into IPTV smarters pro, loaded from Troypoint and on a new 4kmax, and it was accepted. It worked but keep going back to your home screen every 20 seconds. So I uninstalled smarters Pro and put in info again. The same thing occured again. I did this on another 4k max at another location and it did the same thing. I have it installed on an older 4k and it works.
2024-10-10T04:00:00Z
Do you have to use Smarters Pro? If not then consider paying for a lifetime sub of TiViMate or get Sparkles. Both are good IPTV players.
ALSO:
