Is there a new code other than (12341234). When I open that in the Rapid app it opens but stays black and white and will not let me download. I am trying to download Cinema HD.
Thanks
There is other codes but 12341234 does work, after you enter the code you need to wait a couple of mins.
I got unlinked up but it is still in black and white. The icons are not turning to color. I am just having this issue on this fire stick. Should I factory reset it.
Hey @stew62 I wouldn’t resort to a reset quite yet. I just have a couple of ???s for ya so I know where you are in the process. Do you have the Unlinked app icon sitting with all your other apps?..or are you still trying to download it from the RAI?
I got unlinked up but it is still in black and white. The icons are not turning to color. ???
And…Sketch has another easy option also.
Thank you appreciate your help
Any solution to this issue? I am experiencing the same issue when using code 12341234.
I just used code EB2E4A4C and was able to download Cinema. Apps were not greyed out like when using code 12341234.
Need to wait for it to fully load, I use unlinked and was on it today. It’s working.
But I’m glad that other code working too.
A notice quickly flashed stating that the 12341234 code was unavailable.
Im on it now, takes 2 to 10 seconds sometimes to load. Everything seems to be fine. Put in the code and just wait.
@azhawk Thanks for the alternate code, worked great. I am also having a problem with the store code 12341234. The icons that are grayed out will not let you download.
Same with me, but the alternate code doesn’t have the app I want to download
I don’t know why you are saying it’d grayed out. But at least the alternative code is working for you.
12341234 is working
@TP-Dracoo This is what everybody is talking about. Most icons are just white and gray. The only ones that will let you download are the ones in color. I reinstalled unlinked, reinstalled.
That would indicate to me that they are doing a mass update to the latest releases or mods. Give them a couple of days and all should be g2g again.
I have to agree with @Miki. I’ve had this same issue since yesterday of some grayed out apps that won’t download but in the past I’ve come across the same problem and the issue was fixed in a day or two.
