Downloader code doesnt work for me.
double check the code its working fine
Got it up and running.
Just installed new Cinema HQ, looks good do anyone know the password code for adult section.
you set your own password
Thanks
How did you get it working. Ive tried multiple times and got the same result you did the first time
Forget it . Had to change the country setting on my vpn
how can you switch the audio on cinema hq because the films start playing in the wrong language
you cant at the moment there maybe a few in foreign language but not many all you can do is use subtitles
Hi All I downloaded the HQ app and it worked fine until I switched my KM6 Deluxe on the next day to find it was disabled with no option to re enable it only uninstall. I uninstalled it and loaded it again for the same thing to happen the next day disabled again. I tried to turn off play protect but no option to do so in the play store and I searched for similar problem on here to no avail. All the info about says it should be switchable but its not. I also tried under the other suggestions but no good there also.
I am perplexed but suspect its because the android version is 10.
Canât get it to create passwordâŚ
you create the password but i wouldnt bother its not working anyway
Itâs Android 10. I have the same problem with TiVo. Iâm gonna buy another ONN Pro and put TiVo Android 10 in a drawer !
Me either, will not create a password
Wich option should I check ? Support the app or donât support the app button ?
Donât
So can watch all the NFL game on the live tv when CINEMA HQ started having live tv wow i been out the loop for a while
Thanks Dave Its android 10 problem I proved it by trying a Mecool KM 9 deluxe and it gave the same results. I have a shield pro 2019 and that is fine and also Strong Leap one box which is exactly the same as KM2 that have a play protect switch on off.
hello where can we find the download for cinema HQ
