If I install a Port Gigabit Unmanaged Ethernet Network Switch,would I still need a router
yes, the switch just gives you extra ports to plug in devices. A router is a firewall
so,can I connect the switch into the router.what I’m thinking of doing is setup the cube
yes its modem>>>router>>>>switch>>>devices
ok thank you .I got it.I want to replace my firestick with the cube.that’s what I’m trying to do.always running out of storage on my firestick.
