Network drops mbps
My network drop 220 to 76mbps once I open kodi app
76 is still enough to stream tho.
Problem is kicking me out
You never mentioned that. Your network dropping to a lower level is one thing, so now we need more info to help. You should be more descriptive next time. What device? what version of kodi?
I’m using Amazon fire stick 4k
TP-LINK ARCHER 4000 ROUTER
CENTURY LINKS AS PROVIDER FIBER OPTICS
CONNECTION THRU OUT THE HOUSE
Sorry kodi versin 20
kodi is resourrce intense and firesticks need regular maint to keep up. Try clearing cache in kodi and see if that helps.
Already did. Nothing happened
I even restored the fire stick to factory default
And re download kodi. Yesterday
Downgrade to 19.4 or 19.3 for kodi, use a single addon
I will try that. I was thinking changing vpn.
Using NordVPN right now. Any recommendations
Nord has known problems with firesticks.
FYI. I had a friend did a test on kodi 20 on a shield and when opening and using kodi 20 it used 2.2GBs of RAM. Now the max has only 1.8 of RAM. So this could be your issue. On the Max and similar devices I would use a Troy kodi fork with a couple of addons. Kodi is RAM intensive and with so much in a build I don’t think a Firestick will give you a great experience.
Great. Thanks :heartpulse:lets try that
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
