Hi all new to this. I am having a problem lately with my ipvanish disconnecting while I’m using kodi any help would be great thanks. Im using it on firestck
Hi welcome to the platform.
1 First thing to do is check the internet connection.
Clear app cache and try a different server.
If didn’t help.
2 Uninstall and reinstall the app this could help, but you must login again, and connect to any server.
3 If the disconnecting problem didn’t solve
Contact IPVanish support.
If above steps didn’t solve the problem consider new VPN provider.
Thanks Matrix will give them a try and let you know
