While I see that you can record more than one program at the same time, provided you have multiple connections, I can not find any information on how to do this this online. Or I don’t have the right search parameters; everything indicates that you need multiple connections, 1 to watch and 1 additional connection for each recording. It also says only one connection can be installed on one box… Does anyone know where to find instructions for this?
It has been covered alot on these fourms.
I would start with a search. And yes you will need more than one connection.
Sup FD…
The connections come from your provider… u have to pay for more connections…
Tivimate will automatically know how many u have (u can check it in xtreme codes parameters in settings…
HTH
Thanks for the advice TP-Dragon.
Thanks Sketch, I knew that I needed multiple connections, I just couldn’t find how to set it up. The fact that Tivimate knows how many connections there are is the missing piece to my puzzle!
Again, many thanks, Douglas
Thanks TP-Draaco. I have been trying to find a goof IPTV with 4 or 5 connections. So much info to look at with each IPTV company… Wish me luck.
Try installing a freebie url and run a test on multiple recordings.
