No audio on MSNBC STREAM, ONLY PICTURE
I suspect you’re using mx player and it’s missing a codec. If this is the case open the app you’re using and find the player in settings and switch back to the native player. Also if you want to try it, when you start a stream look in the top right of the mx player and make sure HD+ is chosen.
