More than 1 Usb sticks
I have a usb hub that works great with 60 gig fire stick. I am wording if i can add a second stick and use it as external storage? Is that possible?
It is possible, but the Firestick will simply ignore one of the drives. It will only access and read one at a time.
Thanks didn’t think so
To use multiple storage devices they would need to be in a raid array and Im not sure if firesticks would even support that format. I do record to a raid from my stock android and works fine.
The Firestick is so under powered I’m not sure it could ever, or ever did, support RAID. Maybe the 3rd gen cube, I read where it supports ntfs and large TB storage if you’re into that. With the Cube I doubt I’ll need to add anything more than a dongle for my mini keyboard.
