When I try to play a show using Ezra (via the Ezra Source Select player in TMDB Helper), I get a message saying I’m missing an “Is_Resolvable” flag and given a choice between a Yes, single source and No, multiple sources. (If I click on No, multiple sources everything works, but I’d like to avoid the irritation.) I assume this is due to something I’ve messed up in settings but I don’t know what I did and how to fix it. Any suggestions?
I’ve also seen this in The Promise, which I no longer use, so I assume it’s some pretty general setting. It would be wonderful to have a guide or at least explanations for the settings that are common between addons, as well as for those that have different names in different addons…)
