Originally published at: MECOOL KM3 Review - Unbiased Review with Both Good & Bad
This MECOOL KM3 Review was written by Troy from TROYPOINT after using the Android TV Box on a regular basis for one week. This streaming device was provided free of charge to TROYPOINT by MECOOL. However, this review is unbiased and you will see that I point out both the good and bad regarding this…
Can anyone recommend a universal remote to use with the mecool km3?
Will the mecool km3 remote control tv power and volume?
Thanks for the info Troy, if I may ask 1 question. Is there a box running Android TV that will work.
Hi @RonF
Yes, someAndroidTV boxes (boxes that have Android TV OS)do have the ability to control both sound and power.
Can you list them ? All the reviews and manufacturers leave that info out. Guess it’s not important to most folks.
Thanks in advance
I am just populating a new KM7 with apps and the remote is controlling the sound on my LG tv. Eventually I will be using my Yamaha sound bar so I don’t know yet if it will control the sound on that.
