M3u file stops for couple seconds every minute
I have some m3u codes I got from telegram. The channles players but a few of them will hesitate a second then start back up then play about a minute before it hesitates again for another second. They just keep doing it. Is their a trick I cane do to fix the hesitation or is it just the nature of the beast? I am running them in Tivimate.
99% of the time the issue lies in the m3u codes and not the player. My guess is that those codes from Telegram are not very reliable.
That’s what I thought also. I’ve gotten lucky at times an got some good ones from their on occasion.
Hey @scooterboy952 have you tried using an external player for a test? Like Just Video Player. It’s in Troy’s ToolBox :toolbox: . I’m curious to see if that helps.
I just tried the Just Video Player but it didn’t solve the problem but the MX Player Pro did eliminate the hesitating so for​:crossed_fingers:. Miki your the man.
Excellent. Good to hear. Tx for testing that out @scooterboy952 . Have a good Easter Monday.
You too Miki.
I did not know that was a thing :eyes:
