Good day I have to reinstall LooNatics but even though I am entrring yhe link code exactly its not activating.
Any suggestions or id there a recent problem with that addon,?
Thanks Alan
Pretty sure it was taken down. I tried many times.
Try https://warehousecrates.github.io/TheWareHouse
It seems to be the replacement. Good luck.
Will let you know how I go:slight_smile:
Yes The Warehouse link worked and I installed LooNatics. Thank you
