Live channels in rai troy won't open
I installed live channels from rapid app installer… It installs, but wheni tried to open it starts to open and closes… Uninstalled and reinstalled 3 times, cheated cached, restart fire stick… Same issue… Is there a problem with the apk in rai?
might not be compatible with your android version.
@Hollywood1
There is no issues with the rai. You need a iptv player to play any m3u lists.
Oh, sorry…I need to install tivimate\iptv streamers first then live TV app?
@Hollywood1
The rai isnt an iptv player, you will need tivimate, smaters or some other player to play iptv.
Seems you are correct The Live Channels app will not work. Neither from the RAI or the link I provided. Downloads, installs, but won’t run. Just opens and shuts off. So I went to apkpure and downloaded the apk and installed the app. It doesn’t work either. Appears this is a 2 yr old app that hasn’t been updated.
