Got the latest firestick update from Amazon this morning and noticed the latest
Kodi app would not open. My Cinema even still works. This happen to anyone else? And is there a trick to get Kodi back or should I just uninstall and install it back? Thanks and love this place!
BTW developer options is still there.
Probably ran into a space issue, id reinstall it.
You could try to clear the data in Kodi on the firestick manage apps, if that doesn’t work re install it.
Try to go to the Firestick settings- Managed apps- Kodi- clear cache and force stop- then try to restart
Thanks to all who responded. Jack’s was the easy fix I was looking for, worked like a charm.
