Dak7385
January 6, 2022, 11:52pm
#1
Hi. As a fairly newbie to kodi, can someone explain, that on troypoints list of add ons, Seren is shown in brackets (premium add on).
Whilst the list of add ons on troypoints list, do not have the addendum of (premium) .
What is the difference or what does premium mean in this context?
Thank you
TXRon
January 6, 2022, 11:58pm
#2
I believe its indicating a need for a real debrid account.
Dak7385
January 7, 2022, 12:15am
#3
Thank you. Do you mean that without it, it, it would not work?
Because I use Alldebrid and it works fine. So, I am slightly confused.
I am not being contentious with your reply, just trying to understand kodi add ons better.
Regards
TXRon
January 7, 2022, 12:17am
#4
just quality of links. If another premium service is working then all good.
@Dak7385
Seren only works with a perimum links service. All debrid real debrid and many others. Without a service seren won’t work which is why it’s labeled a premium add on.
Many thanks. That explains it perfectly.
Regards
