Is it possible to side load Kodi directly on Visio smart tv?
Hi @Robbier123
That would depend on whether there is an operating system of some form installed on it.
Not all smart tv’s have an android or something similar installed on to it.
I decided to delete my answer. Simply put the Vizio isn’t Droid so the answer is simple, you need a “device” Firestick or box.
Thank you for the quick response.
