when I lunch Kodi is spends a long time updating and them hangs and just says working! my internet is running at 65 mbps with VPN on so it cant be my speed.
In my kodi topic there is a guide to speed up kodi, also depending on your device i would use a single addon vs a build.
Yes I thought about a single addon, is there a way to remove addon’s that came with the build I have and just keep a few? also which addon’s do you think are good. Thanks for your help.
Many times that has been posted… Crew addon seren addon with real debrid is your best options. Yes you can remove and uninstall addons.
And no, just remove the build entirely and put on a addon.
Thank you again for your help
