Can someone tell me when Troypoint will have Kodi 20 stable available for rapid Apk? I only see the Kodi 20 Nexus Alpha
Not sure what you mean by Rapid APK. I think you are referring to the old RAI that no longer exists. The following has replaced it.
Thanks for responding. I have the troypoint app on my Firestick and that’s where the rapid apk is which allows easy updates for Kodi.
As we have said so many times, the Rapid App Installer is gone. While it is technically possible for you to still have it on your Firestick, most links shouldn’t work and will never be replaced. This Rapid apk you keep talking about, I don’t know what you mean. The RAI never had anything like that, unless you are referring to an app that I’m not thinking of.
I will see if there is a new troypoint app to download. Thank you for the information
Its not an app its a toolbox, please review the link sent to you twice. It will help you.
