Kodi 20.1 questions
I have Nvalida shield for the new Kodi. When I type in add on in the add source section, I get a box unable to connect. The box says couldn’t retrieve directory information. This coukd be due to the network being not connected. Would you like to add it anyway?
I have surfshark on. Is there any other settings besides the unknown sources I should check?
Kodi mega guide.
Please read this
Before you post or ask about IPTV, Free links or any of that info without a RD account you need to use our search function as this info is HIGLY talked about with tons of info. Bottom line is if you want to use kodi and get free links or streams without using RD it wont happen or work well, they come and go. The best option to use kodi is to pair it with Real Debrid which is covered below.
Check your spelling, make sure its correct.
